Loader t264 Loader controls
   / t264 Loader controls #1
Toddxyz
Huntington WV
Have never operated a tractor. In process of getting my first one.
Does anybody know if you can operate both loader and bucket at the same time on T264? To like keep the bucket level as you are lifting it. I have seem some compact tractors like Kubota that explicitly say you can do this, but can't find anything on the capabilities in this area on the T264.
   / t264 Loader controls #2
Most tractors will do it. Although ones faster than the others but they all should be capable of doing it.
The problem often, comes with the joystick linkages making it hard to get the sweet spot.
I honestly feel that having a 2 lever control versus the joystick would make it easier to do two functions at the same time.
Sorry it doesn't directly answer your question, but gives a general idea.
My best suggestion is to try it out on the dealer if you can make that happen.
   / t264 Loader controls #3
Sorry I didn't see your question until now. T264 you can tilt bucket as the arms are raising or lowering. If bucket is over filled with gravel you need to tilt bucket slightly when arms are way up, otherwise you can spill some gravel onto your hood. Hope you got a T264 they've been replaced by T25.
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
