T2310 won't go in 4 wheel drive
   / T2310 won't go in 4 wheel drive #1
arksdad
Bronze Member
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
I have a T2310 hydro with about 500 hours. It has always been difficult to engage in 4wd. Now it's almost impossible. HELP
   / T2310 won't go in 4 wheel drive #2
This is often binding where the linkage enters the transmission case. Lube and operate with PB Blaster or other penetrant. I assume you try to engage after slightly moving the tractor in gear?
Jim
Still need help. The linkage that is accessible moves freely when disconnected from the arm that goes into the transfer case. That black lever that enters the transfer case seems to be bound up. Is that possible?
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2018 FORD F-150 (A52472)
2018 FORD F-150...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
434669 (A48836)
434669 (A48836)
