T2310 blowing fuses
   / T2310 blowing fuses #1
NW PA
1941 John Deere B electric start
has about 500 hours on it, has blown the same fuse since it was new, the one on the far right of the fuse block that powers 2 of the headlights and makes the lights on the lower half of the cluster work. traced all the wires and didn't find any pinched. I had the cluster replaced about 25 hours ago because the tach quit if that makes any difference.
   / T2310 blowing fuses #2
It would sure be helpful for a little more info. Does the fuse blow when the headlights are operating or even when they are off? That's a 15 amp fuse (I believe) and blowing it means a heavy current draw if it blows when the lights are off. If your instrument panel was drawing that kind of current, all you'd have to do is follow your nose and the smoke to the problem. On my older tractor, the light switch is powered by fuse #4. Fuse # 4 supplies power to the instrument panel and to the headlight relay's coil. Fuse #7 only powers the headlights. When the headlight switch is turned on, power from Fuse #4 goes to the instrument panel for night illumination and to the headlight relay's coil. When the coil energizes, it's contacts route power from Fuse #7 (the far right fuse) to the headlights only. If your Fuse #7 is blowing only when the headlights are ON, then you probably have a defective headlight, connector, or the headlight relay. If it blows with the lights ON or OFF, then the problem is probably the headlight relay shorted or it's socket shorted. Sometimes mice make a home under the cowling where the relays are located and you can't see them from above. You have to remove the cowling under the steering wheel. Knowing the exact timing of the fuse blowing and operating conditions are important to troubleshooting.
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New Long Forks (A53002)
New Long Forks...
