T190 14-02 error
   / T190 14-02 error #1
DGM
I jacked the machine up and adjusted the tracks tension and the greased up the whole machine put it back down on cranked it up to move it and then it beeped 3 times and shut off, checked the code and it shows 14-02 which says in the book (Fuel shut-off pull solenoid error ON)
Is this something that was a fluke or did I possibly do something by what I describe above also can I correct this myself?
Thanks for any help!
   / T190 14-02 error #2
probably your starter dont work now,you can try unplug the fuel shut off and verify if the connector is cleen,if i dont work after this you will have to change the shutoff....i thing is arround 200$$$
LOT LOCATIONS (A52577)
2012 FORD F-550 SUPER DUTY FLATBED (A52472)
2012 FORD F-550...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
