T1510/T2210
   / T1510/T2210 #1
JFS2295
Jersey Shore
None
Both are about the same power, but what are the differences between these two?
Coming from a 1710 so trying to compare.
Thanks.
   / T1510/T2210 #3
Don't see much difference in the two. I have a Ford 1920 which is 33 hp. It is a much larger tractor than the Ford 1700 I had. The loader on the 1920 is weak. Not sure how they are on the two you are looking at. Are you looking at hydro or gear units
   / T1510/T2210
I'm used to gear so would prefer to stay with that. You feel the 1920 loader is weaker then one on a 1700?
   / T1510/T2210 #5
Probably about how the same lifting capability. But the bucket curl is very, very weak. If I get stuck it does not have the power to get me out. From what I can find both loaders are rated for about 800 lbs. I can lift 1000 lb round bales over 4 feet high with both. Just wish the loader on the 1920 was a little stronger.
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
Manac Walking Floor Trailer (A50322)
Manac Walking...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
