T035 - Post Hole Digger
   / T035 - Post Hole Digger #1
Incognito
I have a 1954 TO35 and I would like to put a pto post hole digger on the back of it. I talked to a mechanic who used to work on these little tractors and he says that because the PTO is so low on them, that a standard digger does not work. He said that Ford made a smaller one for the 8N and 9N tractors that work well on these MF's as well. Anyone know anything about this? Thanks.
   / T035 - Post Hole Digger #2
I have a 1957 to-35 and the std post hole digger works fine on it.
works much better than a manual post hole digger.
   / T035 - Post Hole Digger #3
I can't guess what the mechanic was referring to.
If it was the speed of the PTO. Well, you never run a post auger at anything much faster than an idle anyway.
If it was the size of the three point hitch, I is a standard Cat. 1 hitch.
   / T035 - Post Hole Digger #4
The hitch AND PTO stub shaft location in relation to the hitch on the TO series meets with ASAE (American Society of Agricultural Engineers) commonly accepted standards for CAT I hitch. In a nutshell, they're basically the same configuration as most all 3-point hitch equipped small utility tractors. I know of personally, at least a 1/2 dozen folks who use oridinary "off-the-shelf" post hole augers of various brands on TO35/MF35's with ZERO issues.
2014 Fleetneck FMAX212 Gooseneck T/A Trailer (A50323)
2014 Fleetneck...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
