T Post Puller
/ T Post Puller #1
vrman
Joliet, IL
Kubota BX23 & ZD326P
Anyone have any experience with this device from Northern Tool? I think I see how it works, I just cant picture how this thing attaches to a bucket or boom. Looks like a decent price too.
T Post Puller
/ T Post Puller #2
Looking at the picture on Northern site, it bolts to the back edge of the bucket. I believe it is a wedge type device, and it appears to be automatic when setting. I believe you have to flip the lever to release the the post.
I have a T- post puller that is a piece of metal about 3/8 thick shaped like a square S. It is manual, so you slip it on the post and lever down, and when the S tries to straighten, it grabs the post and up it comes.
/ T Post Puller #3
T Post Puller
Sorry, don't have one of those NT pullers.
I use a chain and the hooks on the FEL bucket of my Mahindra 5525 for that job. I'm now removing 1/4 mile of old farm fence.
I really don't like that NT puller design that requires attaching to the side of the FEL bucket. That puts unbalanced forces on the FEL arms. I much prefer the centered method shown in the photos.
It's not too smart to risk bending an expensive FEL when trying to remove a really stuck $3 T-post. Those FEL hydraulics are really strong and it's easy to mess up the arms and or the bucket if you're not careful.
If you go with that NT puller, a word of caution. On one of the T-posts, I was about 6" off center with the chain. When I started pulling on that really tight T-post, the left rear wheel of the tractor lifted off the ground. I reversed the joystick mighty fast. Like I said--those FEL hydraulics are strong.
Also, if your FEL has a skid steer attach plate like mine, be aware that you can pull hard enough so the bucket is pulled loose from the two lower lock pins on that attachment. I did that very thing trying to pull one of the wooden corner posts in my fenceline. Fortunately no damage was done to the equipment.
/ T Post Puller #4
T-posts are very easy to pull by hand with a simple lever mechanism you can get from Harbor Freight for under $20. Using a tractor or a tractor mounted implement for this job is a big waste of fuel, time and money.
/ T Post Puller #5
This is exactly what I do, in the pics.
/ T Post Puller #6
If that puller was mounted on the back of the bucket, where you could see what you were doing, it would work quite well. It appears to be automatic in the sense, that you place the T-puller over the t-post, and the wedge thingy would grab it and you lift the bucket only no tilt. When you want to release it, you pull the line attached to the small levers on the side, and that release the wedge for the post to drop out. That's my take on it. Of course the chain thing will work also, but is time consuming. Would work faster with two people. A 4 -n -1 bucket would also work , just open the bucket and grab the post and close, lift up.
/ T Post Puller #7
I think you are right about 99% of them. They should come right out and it takes a lot of time and fuel to use a tractor when it's not necessary.
There will be times when the tractor is needed.
/ T Post Puller #8
I have the same maunal type puller that I bought from Harbor Freight... about $20.00. Works great and it takes about all of 5-10 seconds to pull a T-post. It's quick and easy.
/ T Post Puller #9
Junk. The main weld on my HF puller cracked on the 4th post.
/ T Post Puller #10
That makes more sense.
I was going by the photo on the NT webpage
SpeeCo Tractor-Mounted T-Post Puller, Model# 16110800 | Wire + Tools | Northern Tool + Equipment
that shows the gizmo attached to the side of the bucket.
/ T Post Puller #11
Have also used my HiLift farmjack and a c-clamp or chain. Bent a c-clamp once though.
/ T Post Puller #12
I have had my HF lever puller about 5 years now and it has never let me down. Evidently, sometimes those folks in the far east make a good weld and sometimes they dont. I am pretty handy with a welder, so I wouldnt have any trouble beefing mine up if I needed to, but as stated, it hasnt needed any repair yet. I will admit that buying HF stuff is a gamble, but my satisfaction with thier products has run above 75%. One of my other favorites is a 1/2" hammer drill I got about five years ago half price for around $15. That thing has been tough as nails. Also, a 10 year old, 3/4" drive socket set has been trouble free. A mid-grade tap and die set also has given me a pretty good bang for the buck. The loosers have included a cheap palm sander and saws-all.
/ T Post Puller #15
I usually either pull them out by hand or one a tough one use a chain with the FEL. Sure costs a whole lot less than buying a T post puller.
/ T Post Puller #19
You might be right in many cases but when I put my T posts in 25 years ago I was a pretty strong yong buck and drove them deep. Since then they've rusted to the ground. I need to use the 3pth, chains and some creative attachments to pull those rascals now. I haven't tried the product you're mentioning here so it may work but I know T bars can be challenging to pull out of haevy clay ground.
/ T Post Puller #20
I use my head instead of my body for jobs like this. The FEL can be replaced when its wore out, so the heck if I am breaking my back pulling on T posts.
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2021 CATERPILLAR 301.7CR EXCAVATOR (A62129)
2021 CATERPILLAR...
2007 Nissan Altima Sedan (A61569)
2007 Nissan Altima...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
