T-handle Clamp Bolt for Bucket-mount Projects - where to buy?
   / T-handle Clamp Bolt for Bucket-mount Projects - where to buy? #1
Colonel Monk
NW Lower MI
Kubota L2250
Howdy
on these debris forks by Northern tool, they have the T-handle clamp. See LINK: Load-Quip Steel Debris Forks — 1400-Lb. Capacity, Model# 29211774 | Bucket Accessories| Northern Tool + Equipment
Does anyone know if there's something commercially available that includes the swivel pad at the bottom?
Can fabricate it I suppose but was curious if there's a source.
McMaster Carr has "replacement swivel pads" for C-clamps but they require a ball end. They also have "mounting feet" that are threaded female for threaded rod, but generally the bottom of those is smooth and "non-serrated" like the one used on those debris forks.
I've got about 15 projects I want to do for bucket-mounted implements and I know for a fact the old man will **** a brick if I drill holes in his bucket. For the record, I'm not a high school kid (though at 45, I'm told I sometimes act like one) but it's "his" tractor and so I constantly have to worry about his nonstop worry that I'll break it. :laughing:
So the plan is to use both clamps and chain/chain binders to retain the implements.
One the projects I'm going to do with my new welder is probably build those exact debris forks, in theory anyway, for our tractor.
So if you know of anything or have come up with your own solution, let me know. Pictures are welcome too.
CM
   / T-handle Clamp Bolt for Bucket-mount Projects - where to buy? #2
Just do as I did.
Buy a length of 5/8 all thread rod, some 5/8 nuts (long 'splice' nuts can be had) and weld 4-5" cross rods as a "T" fashion.
OR if you don't want 'T' handles simply weld a nut to allow a spanner to close the clamp tight.
While swivel heads might be nice, a tapered end also works quite well.
You didn't have any issues with T-handle backing out?
Willing to try it as long as it works, just seemed like people have a need to build custom clamps so I was surprised I hadn't found any yet.
MODS - please delete the extra threads - something was wrong with the site this morning, I tried multiple times to post but it kept telling me it couldn't contact the server - didn't realize multiple went thru.
   / T-handle Clamp Bolt for Bucket-mount Projects - where to buy? #4
You can delete the thread with no replies, by clicking "Edit" on your post, click "Go Advanced", click "Delete this post in the following manner:", click "Delete Post".
http://www.tractorbynet.com/forums/build-yourself/326164-t-handle-clamp-bolt-bucket.html#post3955298
This also works for duplicate posts.
   / T-handle Clamp Bolt for Bucket-mount Projects - where to buy? #6
I keep old C clamps i buy at auctions for such projects. Just cut them off and enjoy the built in swivel foot.
   / T-handle Clamp Bolt for Bucket-mount Projects - where to buy? #7
"You didn't have any issues with T-handle backing out."
Nope, being tapered a lot of pressure is exerted at the tip.
Note, when I say tapered I don't mean sharp end but approximately a 45% dull taper, just enough to prevent the end from walking in circles as you tighten.
12in Backhoe Bucket (A53472)
12in Backhoe...
2023 G Bar K Goose Neck Flat Bed (A53472)
2023 G Bar K Goose...
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
32" FORKS (A51247)
32" FORKS (A51247)
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
