I run synthetic in everything I own that has a motor. My shop air compressor, lawn mowers, and my Harley.
The tales are still roaming about how synthetic won’t seat your pistons, your engine will leak etc. Don’t listen to it. Sure if you run synthetic in motors that were built in the 70’s you are bound to start getting oil leaks. With the advancement in Synthetic oils and its benefits engine builders took note. Engines are of closer tolerances now. A current Chevy 350 engine actually has almost twenty five percent less gaskets in the motor compared to the same motor built in the 70’s. Also, with Synthetic motor oil please realize that you are only getting a couple of ounces of actual synthetic oil in that quart. Better then two thirds of the quart is standard oil. (Synthetic needs a carrier). This also blows off the notion that once you use Synthetic you can never go back to regular oil. One other note, if a dealer ever tells you that you need to run “their brand of oil and no other brand” the dealer has to supply you with their oil – Free of charge for as long as you own your vehicle. Run Synthetic!
PS
Family has been involved with Mobil Oil for over forty years.
