Synthetic oil
   / Synthetic oil #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
Recently I bought an old beater from my BIL. He had bought it from some guy that was getting deported.
Bil told me he thought it had synthetic in it but isn't sure. I can I add regular oil to it now and can I change the oil and put regular in it.
I seem to remember that the HD dealer told me they couldn't be mixed and once you use synthetic you can't go back. My bike is the only thing I use it in because it saves buying 3 types of oil.
What should I do not really knowing what's in it?
Sent from my iPhone using TractorByNet
   / Synthetic oil #2
Mix away and it makes no difference. Synthetic is a "better" product because things start easier and lubrication starts earlier in the run cycle. Engine oils mix but maybe add now and change when you get around to it.
Research apparently shows that proper oil changes with regular dino oil is as good as synthetic for older equipment but those are fighting words. Synthetic costs more but you can go longer between changes. For me I use synthetic everywhere I can, even in older things. No problems ever.
If it were me and it was a beater I would run something like Delvac 30W or even 15W40 for at least the first oil change just to start to clean things out. Then I'd assess and probably go synthetic.
   / Synthetic oil
Thanks I'm just not sure what's in it. I wasn't sure I could mix it or switch back to regular. I guess what Harley told me was typical sales techniques for them.
   / Synthetic oil #4
Check the syn container. Usually it will say that it mixes with anything of the sort.....other oils.
On what to use, I think the oil display at WW says it all. No where in the store do they have more of the "same things of sort" than in the oil section of the auto dept. Speak well of the different opinions you will get. WW doesn't stock something that doesn't sell so it speaks for itself.
Mark
   / Synthetic oil #5
YES you can mix ... the oil becomes the lower standard oil ( less flow at lower temps and can't handle the synth higher temps ) ... doesn't hurt the engine or oil.
you can switch back and forth in older machines ( but the synth may weep out past any hardened oil seals, and you may burn a bit more at startup )
BUT if the engine spec calls for synth , use synth
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
