Synthetic hydraulic fluid
   / Synthetic hydraulic fluid #1
jmfox
Platinum Member
Any opinions/experience regarding synthetic hydraulic fluid?
jmf
   / Synthetic hydraulic fluid #2
This topic has been discussed at length in numerous other threads... suggest you search on "hydraulic fluid synthetic". Some love it, some say why bother. Some say it is only useful in very cold weather areas. I use SUDT which is NOT synthetic, although some think it is, but is certainly expensive. :eek:
I am familiar with the debate. Maybe I should have been more specific as I wonder if my ASV SR80 can use a generic hydraulic fluid? The only recommendation the manufacturer has is their own brand (Posi-Lube).
jmf
   / Synthetic hydraulic fluid #4
Unless your in some very extreme enviroments I would stick with a good high quality conventional oil. Group II base stock hydraulic and UTF oils perform very well in all but the most extreme conditions. Start a regular scheduled used oil analysis to monitor the oils condition and use it to gauge your drain intervals and condition.
2012 Ford F-350 Omaha Service Truck (A51692)
2012 Ford F-350...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
