Dec 27, 2014 / Switching Hydraulic Pump for speed #1 A AdvocatePrinting New member Joined Dec 27, 2014 Messages 1 Location nashville,tn Tractor jd 2305 I have a JD 2305 and the hydraulics are a bit sluggish. Can I replace the pump or increase the flow to get more speed? Thank you! MS
Dec 27, 2014 / Switching Hydraulic Pump for speed #2 O oldnslo Super Member Joined Jan 20, 2010 Messages 8,112 Location Northern, IL Tractor Branson 2400H, JD X540 simple answer is yes IF the rest of your system will handle the increased flow rate. I.e. are the lines and valves large enough..
