Switching Fuel Tank from Diesel to Gas
   / Switching Fuel Tank from Diesel to Gas #1
idaho04
I just obtained a 200 gallon farm tank from my neighbor. Way too big for me but better than nothing. It was used for farm diesel. I would like to use it for gas. What do I need to do to clean it, rinse it, before I put gas into it?
   / Switching Fuel Tank from Diesel to Gas #2
Nothing other than drain it. Make sure you drain it completely to get any water out.
Edit: and check it's interior condition. You don't want to use a tank that's rusty inside.
   / Switching Fuel Tank from Diesel to Gas #3
You shouldn't need to clean it out to much. A small amount of Diesel won't contaminate the gas. As cp1969 said I would check to make sure it's not rusty inside. Also, on a gas tank you should install a 10 to 15 foot tall vent tube on the top of the tank. This will prevent gas fumes from accumulating near the ground.
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
CAT 420D IT (A47477)
