Switched to a Diesel generator
   / Switched to a Diesel generator #1
techman
Veteran Member
N.E. PA
BX22
Living in a somewhat isolated rural area, I have had a backup generator for years. It is truly nice to have during an extended outage, since the well pump will not bring you any water without power, and heat and lights are nice during an extended winter outage.
For over 5 years I have had a Coleman 7KW with a Briggs V twin OHV engine. Nice unit that ran quietly and reliably (located in my shed about 50' from the house and hardwired to the transfer switch). It did a great job powering the necessities and frivolities of life. Then came the Kubota BX22. That purchase resulted in my becoming a diesel economy, and I found myself not using for the 5 gallon gas cans as before. Sure I keep a 1 gallon of mix for the chainsaw, wacker and blower, but the large container of regular gas just sat there. I grew concerned that when I REALLY needed the generator, I would have 4 or 5 gallons of old stale gas that would barely run or even kill the generator. So the decision was made.
I looked for over a year for a "deal" on a diesel generator, but I found most prices a killer. I really wanted a Kubota powered water cooled unit (commonality of parts, etc), but nice units were $ 6K to $ 7K ... way too much. Anything water cooled in my price range was generally a military surplus or other high hour used unit, that could be a maintainance nightmare.
Finally I found a guy through an eBay sale. He was selling a 10/12KW unit with a Deutz engine for $ 2700. It was a "buy it now", so the price was set, and the unit was new (he had over 20 left last I heard). I did a little research on the web on the engine and alternator (a Mecc Alte) and decided to buy.
I got the generator last week. The engine, a Deutz/Ruggerini MD151, is a 2 cylinder air cooled unit (would have preferred water cooled, but wasn't going to happen for my price), with transfer pump, elec start, optional spin-on oil filter, high capacity oil pan, high capacity fuel filter, low oil level float switch type shutdown, large quality muffler, and solenoid (electric) fuel cut-off shutdown. Nice engine with all of the options. The alternator is a heavy frame brushless type direct coupled to the engine.
I needed a fuel tank, so I got a 12 gallon above deck plastic tank from BassPro for $ 40. It has a level indicator and a suction line, but I had to add a return port, which I fashioned from some fittings, gaskets and a brass drop line. I mounted the generator's channel frame to a large wooden frame using 4 rubber vibration isolators from Grainger. Lastly I had some exhaust pipe bent up by the local muffler shop. It attached to the engine's muffler and extends through the shed wall to the outside, with a piece of flex line near the engine.
I fired it up and it is very smooth and not very loud. I say "not very loud" because the mechanical noise is quite a bit louder than the old gas generator, even though the exhaust noise is minimal.
I have yet to make the final electrical hook-up (need new wire), but it is all but ready. A nice unit that will now sip the same fuel as the tractor, and provide a bit more power to boot. at under 1/2 gal/hour for 3/4 load, my 50 gallon diesel tank will provide a nice reserve for a bad situation.
BTW I did consider a PTO generator off the Kubota, but the cost with all of the required pieces was $ 1200 to $ 1500 for a comparable size. It would tie up the tractor, which in the winter could be a problem if I needed to blow snow, and it was for sure not a wife friendly system to hook up I was not home.
I will post some pictures in the next day or so.
paul
   / Switched to a Diesel generator #2
I'm in the same boat. I looked at utterpower.com and thought of getting a Changfa Diesel and one of the ST10KW Gennie heads. George makes a pretty convincing case and I think his route would be just a bit cheaper but I'd need to fab up a mount and such. The bonus is that the Changfa 22HP Watercooled Diesel runs about $900. Similar cash outlay, but probably a little more longevity.
Do you have the contact info for the eBay guy you bought from as that doesn't sound too bad of a deal.
Thanks,
JP
Here is a view of the exhaust line outside
paul
A view of the exhaust line from the genset to the outside pipe
Closeup of the genset
paul
Last a shot of it in the corner of the shed near the Bota
paul
   / Switched to a Diesel generator #8
Exhaust can get hot. Any worry about the siding catching on fire? I don't think I'd want the pipe touching any wood.
As you can see there is a plate on each side, with a bit of a clearance hole between the pipe and the plate, so the pipe does not touch the wood.. The hole in the siding is much larger than the pipe, and the gap is filled with steel wool (a very good insulator believe it or not).
I used the same exact scheme (and hardware) with my gas generator. The only difference is that the pipe is now 1 1/2" instead of the 1 1/4" before. There is not even any darkening of the wood siding under or around the plates. If I had seen any signs of heat on the wood I would take action, but it has so far been fine.
paul
   / Switched to a Diesel generator #10
Sounds good to me. Thanks for the tip.
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A55218)
2018 Link-Belt LBX...
