BruceWard
Platinum Member
I want to build a walking and if possible gator trail down a 30 degree slope. I have decided against building the trail straight down the hill. I can not pave it and do not believe it would hold up to use without paving. I am considering the possibility of using a mini excavator to cut into the hill building switchbacks. If I can not build a trail then I will eventually build a gondola or tram system. The hill is covered in large trees and rock. The big issue in using an excavator would be dealing with the stumps and rocks.
The hill drops 82 vertical feet in 138 horizontal feet. The face of the slope is 161 feet long and I have a 200 feet wide area to work in.
I am considering build a switchback that would start in the middle of my property cutting over to the west edge then cut all the way across to the east edge and finally cutting back to the middle at the bottom. This would increase the distance of the trail to around 412 feet. By my math that decreases the slope from 31 degrees to 11.
Here are some pictures and a topo map of the hill. I appreciate any and all suggestions.
Looking up from the bottom.
Side view, cleaning up when the water was down 9 feet
From the top looking out
Topo map indicating the path
