Swinging drawbar extension???
   / Swinging drawbar extension??? #1
Wal
East/Central Missouri
Kubota B7500HST (Kobi)
How can I fix this problem guys? I have this 4x8 trailer I got from Harbor Freight. You know, the kind that folds up /w3tcompact/icons/smile.gif. I got the one with 12 inch wheels for extra clearance in the woods. It works real nice except for one, teeny, tiny problem. The dang /w3tcompact/icons/mad.gif front "A-frame" hits the back tires even during just a moderate turn, let alone a sharp turn. This is, as you might guess, is a major inconvenience dodging trees and such. This trailer has the ball coupler right at the end of the "A-frame", with no straight extension which would put the coupler away from the front of the trailer. Anyway, to try and make a long story short, the problem would be solved if I could: 1. Extend the ball coupler away from the "A-frame" by maybe 18 inches or so, or 2. Somehow extend the swinging drawbar out from the back of the tractor by the same 18 inches. This is a B7500, by the way. I have tried using a 3 pt hitch drawbar, but its just the same problem except then the trailer frame is hitting the left or right side of the 3 pt drawbar. Has anyone made or bought an extension for their swinging drawbar? Any details would be helpful /w3tcompact/icons/smile.gif
   / Swinging drawbar extension??? #2
Sorry for this goofy question Wal, but have you extended the drawbar as much as possible? I believe I have 3 options for pin placement on mine.
Kevin
Kevin,
Ah, if it was only that simple . . . . . . /w3tcompact/icons/tongue.gif. Yup, the drawbar is out as far as she'll go, Kevin. In case anyone has trouble deciphering my description of the problem, here is a schematic of the trailer.
   / Swinging drawbar extension??? #4
Wal:
I just bought a 4' piece of 1/4" thick wall square tubing from a trailer dealer at $2 per foot. I'm sure it would be cheaper at a steel company. The trailer place also had a hitch made to go on a 2" trailer tongue. My recommendation is to buy the length of tubing you need to reach all the way to the frame cross member and weld it on as a new tongue. If you don't want to go that far back, you could also just jave it extend about two feet behind the current hitch and put a cross piece of the same tubing on top of the A frame channels. Either way, it should be plenty strong.
   / Swinging drawbar extension??? #5
Walter, I'm in agreement with Charlie Iliff (if I understand what he is saying). I think you should extend your trailer tongue instead of the drawbar. If you get too far back on the drawbar and you have a heavy load on your trailer, you will get very light on your front wheels. I'd modify the trailer. ...my two cents.
   / Swinging drawbar extension??? #6
Could you make a tongue Extention to move the A-frame farther back from the hitch? Down at the boat ramp they have a piece of 2 inch square tube with a hitch on one end and a bracket on the other end that hooks on the trailer frame there is a ball mounted to the tube that goes in the traler hitch. Lets you get the trailer far enough in to launch the boat without emerseing your car.
Chris
   / Swinging drawbar extension??? #7
Wal, that's precisely why I made the contraption you see in the attached picture. It gets the hitch on the 3-point so I can easily raise or lower it, and it gets the ball back behind the drawbar so I can turn quite sharply with either of my trailers or my neighbor's trailers.
   / Swinging drawbar extension??? #8
Wal:
Bird's attachment is a better idea than the trailer modification I recommended.
   / Swinging drawbar extension??? #10
Wal, I made a hitch to mount on the 3pt. My trailer is also an A-frame and with the hitch I can have the trailer at almost a right angle to the tractor without it hitting. Northern sells something similar if you don't weld. You can see my hitch at:
http://www.mgsweb.com/tractor/hacker/hitch2.htm
I used it quite a bit the last few weeks hauling lumber for a fence in the woods and sharp turns were never a limiting factor. I think having the hitch ball further to the rear also makes controling the trailer easier when backing up.
Andy
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51246)
2016 JLG ECOLIFT...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
Almac Fuel Tank Body (A51692)
Almac Fuel Tank...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
