Swartz wide front on 3010
   / Swartz wide front on 3010 #1
Blueflint
Winchester, Ohio
Deere 1020
I'm going to be looking at a 3010 next week that has a Swartz wide front end. I know there have been a lot of Swartz wide fronts used over the years but I am unfamiliar with them myself. Are these good or bad or??? What should I look at or be aware of? Any common problems? Thanks.
   / Swartz wide front on 3010 #2
The schwartz front ends weren't as strong as the factory ones, but for average use they were ok. I would not recommend one for a loader application. I would look it over carefully for signs of previous breaks with patched up welds or bent spindles. If everything looks straight and the tires are worn evenly, you should be ok.
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
International 5088 2wd Cab Tractor (A52128)
International 5088...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
PALLET OF FENCING (A51244)
PALLET OF FENCING...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
