suspension seat?
   / suspension seat? #1
dslanec
Northern Michigan
CUB/YANMAR SX 3100
Has anyone put a suspension seat on the sc 2400? I have just started looking and thought I would ask on here first. If you have please tell me which one and how easy the install went. I am also wondering if this will effect the seat saftey switch?
   / suspension seat? #2
Most seats of comparable size will interchange. Changing size in width and height might make a difference of what will work!! You might have to modify the mounts to get them to fit.
   / suspension seat?
Thanks for the reply.Im trying to find one that is a direct replacement. Im not the best at modifying something to fit.
   / suspension seat? #4
I have a bad knee and use my tractor a lot, its what I do for the 15 hrs a week the Dr lets me work. You can put a suspension seat on and they do really help however they are not a direct bolt on like they said above that being said its not hard to do just drilling a couple of holes is all it took. Go talk to a neighbor or a welding shop they may even have an idea of where you can pick one up.
   / suspension seat?
I just saw this on ebay. KUBOTA YANMAR BOBCAT MF JD CASE FORD DELUXE TRACTOR SEAT W/ FULL SUSPENSION | eBay .. My bolt pattern is 7" x 11" so i think this would work? Im just afraid it might sit to high? From the bolts to the top of my seat is 8-8.5 inches. this one does not show that distsance.
Also does anyone know if i will have to deactivate the seat switch? I would rather not but can you make it work with a aftermarket seat?
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A52748)
GOODYEAR SET OF...
2000 FORD F-650 DUMP TRUCK(INOPERABLE) (A52472)
2000 FORD F-650...
2016 Ford F-550 4x4 12ft Landscape Dump Truck (A50323)
2016 Ford F-550...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
Loader Arm (A51691)
Loader Arm (A51691)
Trailer w/ 500 Gal Tank & Pump (A50121)
Trailer w/ 500 Gal...
