Surge Brake Bleeding
   / Surge Brake Bleeding #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Having just replaced the two flexible hydraulic lines to the drum brakes, I'm having a problem bleeding the system. The master cylinder is full and the trailer emergency brake is off on this two axle rig. Shouldn't the fluid keep coming thru each bleeder valve as one goes to each one? All I get is an initial flow of about 25 cc from each wheel, then nothing more. Using the Mityvac Silverline tool, I'm pulling 25-30 inches of vacuum. What's my problem?:( This thread will not self-destruck until someone accepts this mission. :laughing::laughing:
   / Surge Brake Bleeding #2
I don't know if this will b any help or not. You are power bleeding, you might try the old fashioned way of just pumping the master cylinder. I have had 2 boat trailers now, with surge brakes, and used to have some problems, but then I figured out, that I needed to put the tongue down hill. I let it sit for a few hours and then start manual bleeding at the side that is the farthest away, and then move to the near side. What actuator are you using? I have used an atwood, and now a ufp, and on both of these there is a spot to stick a large screwdriver in and pump the master. And btw, most of the actuators, have the manual online so you can follow their specific procedure.
Good Luck, Dave
Thanks, Dave. It looks like I have to take the coupler off etc. to get to the master cylinder, so as to pump the fluid out versus trying to vacuum it out. I don't know what you mean by "actuator".....I don't think there is one on my rig. It is not electric......but what do I know:D It seems like the DIY life is always presenting a new experience. :licking:
   / Surge Brake Bleeding #4
What master cylinder/couple do you have? I do this job dozens of time as year on customers trailers. If its the type that pivots the ball on the ball simply put a ball and coupler in it and pump it up and down to bleed.
If you have the Titan style with the arm on top hooked to a chain for the e-brake simply take the 4 bolts out holding the spring steel pieces used to hold the e-brake on. Now put a piece of pipe on it and pump.
Some pics of your coupler will be helpful.
Chris
   / Surge Brake Bleeding #5
By actuator, I mean the whole front assembly. Like this one UFP _ Actuators, or this one
Surge Brake Actuators - Atwood Mobile
Do you know which brand you have?
I have been around these quite a bit thru, my boats and friends boats, it seems very odd that you would have to disassemble anything to stroke the brakes. If you can post a pic we might be able to help.
Dave
:thumbsup:As always, you guys are most helpful. It is amazing what one can learn by reading the directions. The trailer owner's manual shows that I have a Model DA 20 Actuator....Duh-h-h. Anyway, I like the part where I only have to take the e-brake cover off and pump that. Will let you know how this turns out. Someday I should get a digital camera and learn how to post pictures. Old dogs are slow to learn (or spend money) on new tricks. Thanks again.:)
   / Surge Brake Bleeding #7
I looked up the manual, and it seems pretty straight forward. It looks like you use the emergency lever thing to do the pumping. Don't forget, it might help to lower the tongue to gravity take over.
Dave
:thumbsup::) Thanks Dave and Chris......It's done. The trailer was up on jack stands because I had put a new deck on along with the new rubber lines....also four new tires. Anyway, the rear was raised and the tongue was lowered (but not too steep). My son came over after work and he used the big screwdriver to pump the master cylinder (thru the e-brake access) as I worked each valve. We flushed each valve three times starting at the rear then went around one more time pumping once. I also studied the Atwood site. You guys are the greatest. Thanks.......Mike
   / Surge Brake Bleeding #9
Glad you got it Mike. I have done it by myself with a home made rig on the bleeders but its much much easier with a helper.
Chris
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
