Super UDT
   / Super UDT #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
A while back, I changed the hydrostat oil and filter, and cleaned the screen. I used the TSC Traveller Premium hydro oil and Wix filter. Here's the rub, since the change, I notice that the loader is not as strong and the tractor doesn't pull as hard as before. Is this imagination, why would the fluid make a difference in the pressure relief valve? Is the filter possibly the culprit, being too restrictive? Anyone else experienced this? Dealer doesn't stock Super UDT so he ordered some, waiting for it to come in, also going to use Kubota filter.
   / Super UDT #2
I just recently went to a dealer sponsered owners night at the dealership and that was discussed. Kubota blends its own oil and hydro fluid especially for its tractors. It's consistency and blend is produced just for Kubota. So it is possible that maybe the other fluid is thicker or of a different consistancy than Kubtoa's. I would recomend you go back to Kubtoa's fluids and fliters. My tractor just got it's 50 hrs service and I can't wait to pick it up.
   / Super UDT #3
I didn't think there was anything to it but marketing hype, but one of my local Kubota dealers has a sign up by the parts counter warning that some non-Kubota filters have been attributed to flow restriction issues....
Pete
   / Super UDT #4
Hey guys,
Look in this forum back a couple days to the thread named "Kubota Super UDT Hydraulic Fluid Specs".
It was pretty well discussed there. I use UDT myself.
   / Super UDT
HEY! HEY! HEY! got the Kubota filter and Super UDT installed, cleaned the screen again and used a magnet to clean out the case. Tractor is back to normal, I'm a happy guy. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / Super UDT #7
Glad to hear you're up and running. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
A confirmation that using UDT does make a difference. I've learned my lesson through you that my Kubota won't be seeing anything but it. /forums/images/graemlins/wink.gif
   / Super UDT #9
I used TSC Premium UDT and a Wix filter at 50 hours and experienced reduced FEL and BH power and response. Also had the BH "leak down" to the ground overnight, which it had not done before. It's not my imagination, and I know what to do at the next change (Super UDT!). /forums/images/graemlins/wink.gif
   / Super UDT
I was looking back through some of the old posts and I believe you were the first to post on this subject. I couldn't remember where it was, but when I read it I thought that it must be just your imagination. After I switched, for a while, I thought it was also just my imagination till I started moving a pile of rocks, couldn't even lift a bucket full. I'm glad I switched back, the extra $$$ is money well spent here. /forums/images/graemlins/smile.gif
197359 (A50458)
197359 (A50458)
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
