Super garden tractor hydraulic expert needed
   / Super garden tractor hydraulic expert needed #1
LC7100
Indiana
B7100HST
I have a friend that just bought a 2182 with the Kubota gas engine. After a few weeks the steering did not work properly. He could not turn left, but if he turned right first, then it would go to the left. It would continue to turn both ways for a short time, then he would have to turn to the right again before it would go left. The hydraulic lift on the mower also seems to have a problem. When he lifts the mower it drops a half inch or so before the mower comes up. Otherwise it works OK. Ne he notices that the ground speed, both forward and reverse is not as fast as it should be. He has an older 1972 to compare it to, and the ground speed on the 2182 is noticeably slower.
Would the relief valves in the pump have anything to do with this?
   / Super garden tractor hydraulic expert needed #2
I'm by no means an expert, but the first thing I would do is filter change/hyd fluid flush. I've seen a small dent in a hydraulic filter restrict flow and cause hydraulic problems.
If that doesn't work, then onto valves/pumps....
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
