Super Cub's.....
   / Super Cub's..... #1
Volfandt
Veteran Member
TN
2004 Kubota BX23, 1966 WheelHorse 856
Super Cub\'s.....
Whilst out and about the other day, I noticed a couple of super-sized Cubs on a Cub/Kioti tractor dealers lot and decided to stop & check them out.
One was a 6284 & the other was a 7532. Biggest Cubs I've ever seen....
I liked the feel of the 6284 best even tho it is a smaller tractor. I also was impressed w/the yellow 3 cyl Perkins diesel engine stuffed under the hood. It indicated it had 22Hp.
The 6284 reminded me alot of the Kubota BX & B series. The threadle pedal & dash were layed out like the BX, the larger tires & Cat1 3PH & lever placement looked like those on the B7510/B7610. The front remotes & joystick reminded of the JD 2210/4210.
I didn't see any kind of MMM height adj like the BX and since there wasn't any implements mounted, I'm going to assume that the MMM either has ground contact rollers/wheels or some sort of adj mounted back on the 3PH (like the new Turf Special B7510)
There was no FEL mounted either nor did I notice any mounting brackets for one.
The 7532 is much bigger. While I didn't spend too much time checking it out as I had to leave, the pedal layout also reminded me of Kubota, even down to the twin brake controls being on the right side along w/the hydro pedal.
They looked like very good well made machines but there was no pricing on them so I don't know where they fit compared to the big 3.
One other thing of note is that they both had the plastic/fiberglass type hoods of the same style as the smaller GT/LT Cubs.
And no I'm not shopping, but I do like to check out the machinery, especially ons I've never seen up close before /forums/images/graemlins/grin.gif..
Volfandt
   / Super Cub's..... #2
Re: Super Cub\'s.....
Yeah, they are nice machines.
The 6000 series you saw had the 3cyl Perkins (Cat) diesel in it that is rated at 28 hp. The 7000 series is made by Mitsu. and are good machine too. Both can be had with a FEL and BH.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
2012 Honda Civic Coupe (A50324)
2012 Honda Civic...
Kubota 29" Backhoe Bucket (A50774)
Kubota 29" Backhoe...
2013 John Deere 6105D (A50120)
2013 John Deere...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
