Sun Star starter
   / Sun Star starter #1
strohman
Defiance,Ohio
Kubota. Simplicity.
Hello. New here....I have a 1691528 Sun Star 18HP with the Koehler engine. I believe I need a new starter. Priced one locally at my Simplicity dealer and it was about $225. Does that sound right? I haven`t "dug into yet", but is installing a new starter pretty straight forward? Or is it one of those deals where you have to loosen up the engine to get to it? Don`t hardly ever use this tractor anymore and was debating on whether to even keep it or just sell it.
Thanks,
strohman
   / Sun Star starter #2
What's the model number on the engine? I would not expect the starter to be more than about $70-80.
   / Sun Star starter #3
Was that $225 installed or just parts?
   / Sun Star starter
Model is M18S. $225 was just for the part. The guy said Koehler must think their starters are really special for the prices they charge.
Thanks,
strohman
   / Sun Star starter #5
Some one correct me if I am wrong but Kohler doesn't make their starters. I believe they are currently using Johnson Electric likely from China. I have only seen Sunstar tractors from afar so I am only assuming it is likely that you will at least have to lift the engine to install a new starter. I have a Sten starter on my K341 and it works like a champ. Name brand manufacturers usually offer a warranty which takes away much of the risk you might think you are incurring by buying an aftermarket starter for 1/3 to 1/4 the cost of the OEM ( Johnson Electric)
   / Sun Star starter
Finally had time to do some research. Found 4 starters from a online business. Price from $80 to $190. Cheapest being non OEM, and most expensive is Kohler. Cheapest looking good now. Now need to tear into it to see what all is involved.
Thanks,
strohman
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2019 Dodge RAM 1500 Pickup Truck (A53117)
2019 Dodge RAM...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
