Suggestions on replacing hayloft floor...
   / Suggestions on replacing hayloft floor... #1
amstaff
Mahindra 5530
Just last month we had a major barn renovation completed by a contractor. One of the things that was not done, however, was the replacing of the hayloft floor. The old roof leaked for many years before we purchased the property, and the center of the plywood floor has some rot in it. Not rotted to the point of possibly falling through it while walking on it, but rotted nonetheless. Contractor said to just nail plywood over the exsisting floor...
I'm looking for feedback on how other people would do this project because I'm probably overthinking it!
My first thought is... Is simply nailing plywood over the exsisting plywood taking the easy way out, or is this how it is usually done?? I'm not sure the top (new) plywood would attach all that well down the center of the loft because the floor does have some rot in it. Attaching everywhere else would be fine, though. Would 1/2" plywood be fine (current floor is 1/2")??
My second thought is... Would it make sense to completely rip out the exsisting floor and replace with 3/4" plywood??? This seems like a lot of work, not to mention it would be considerably more expensive then option #1.
Lastly, if I can get away with just putting a new layer over the exsisting floor, would OSB be appropriate? It is a well ventilated and dry hay loft...
Any help would be great!!!
Thanks,
Amstaff
   / Suggestions on replacing hayloft floor... #2
Forget OSB. It's damp in a barn and OSB won't tolerate dampness. I had exactly the same scenario a few years back but I re-did the barn myself.
I replaced the bad floor supports (pegged and tenoned) with pegged 40 retentioin PT timbers of necessary load bearing size (bigger than the original) hardwood timbers.
I used pre turned hardwood doweling for the pegs. Part of the floor was useable so I left it and overlayed with 3/4" 40 retention PT BC Plywood over the bad sections and the good. The I laid on sheets of 1/4" BC plywood as a top layer. You don't want the 40 retention wood in contact with any feed stufs like hay.
Mine has been done over 10 years now and it's as good as when I put it in.
I used Galvanized square drive deck screws throughout.
Barn restoration is expensive if you don't do it yourself....
   / Suggestions on replacing hayloft floor... #3
OSB tends to swell when exposed to high humidity. I would believe the Contractor knew what he was talking about. Leave alittle space between the new sheets of 1/2 as they will buckle when nailed tightly end to end. If it is like some barns around here you may have to redue the floor in 100 years.
   / Suggestions on replacing hayloft floor... #4
Swell and seperate. I neglected to state that I used a couple 10 D nails to space my plywood as I laid it down. All wood expands....
   / Suggestions on replacing hayloft floor... #5
If it's structurally sound, what is your goal covering it up? Is it just aesthetics? If so you might just think about painting it. I like white on the inside of barns, it makes it easier to find things because of all the reflected light. If you cover it with something, make sure there's no mold started. Covering it up could give it a nice environment to grow.
Great info. Thanks!
I wouldn't say the floor is structurally sound... it just isn't to the point where you would fall through it (yet!). If I applied enough pressure, I could definitely put large holes through it - down the entire center of the loft. It definitely needs repaired/replaced.
Because of the swelling mentioned, tongue-and-groove is probably not the best choice... I'm glad I asked this question, because I was thinking about T&G as an overlayment or new floor!
Amstaff
   / Suggestions on replacing hayloft floor... #7
Amstaff, I don't know where you are at but a couple of guy's around here in the PNW are selling old growth 2x6 fir boards taken out of an old pipeline built around the 1930's. They are treated all the way though, and are between 16 and 20 feet long. The are getting 2 bucks a board. They have a slight cup but that can be taken out if needed. They would make a great strong floor, cheaply. I have a friend building raised bed gardens out of them, and I will be using them for the new pump house and the shed for the attachments. Won't root out, but if they ever catch on fire, I think you would never put it out.
I'm in Central PA... Happy Valley!
   / Suggestions on replacing hayloft floor... #9
Amstaff, it would cost a bunch to get it to you, but see if you can find a local sawmill, that sell rough sawn 2 by's. I should be fairly cheap, as no one is building houses right now. We have several small mills around here that are having a hard time paying their workers, so the prices have dropped.
   / Suggestions on replacing hayloft floor... #10
If your current floor is 1/2" just remove the rotted areas and fill back in with new 1/2". If it is easier to remove a whole sheet, when just part of it is rotted then I would do that. Save some time and money by just replacing the bad areas.
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
Croft 5,000lb Vehicle Tow Dolly (A52377)
Croft 5,000lb...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
19015 (A53422)
19015 (A53422)
2011 FORD F-450 (A52472)
2011 FORD F-450...
