Suggestions on how to clean out DK6010 cab and tractor as a whole?
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #1
future_vision
New England
DK6010SE HSA
I have a Kioti DK6010SE Cab and man is is it filled with dust and dirt. What is the best way to clean out the cab? What about the tractor as a whole. Can I pressure wash it without damaging anything?
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #2
Blow it out with one of those blowers or compressed air.
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #3
What I do, use compressed air in the cab and a dust cloth. Outside I use a pressure washer with a low impact nozzle.
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #4
For the cab I use a shop vac and then wipe down with a damp rag. The exterior is washed with a hose and soft bush or power-wash just like my truck.
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #5
All of these are good but reading them a couple of thoughts come to mind. Never wash a hot engine, you can damage it.
The other is combing the suggestions already given. Blowing air will move most anything not stuck but not always easy to direct or steer it where you want it to go in a tight area such as a cab. Vacuuming nozzles have to normally touch it to get the dust and dirt. If you have a shop vac, take the suction hose into the cab and leaf blower or air hose and with vac running blow the dust and dirt to be moving. Vac should find it easy to pull the air with the dust and dirt and no fine steering with the pressured air is required.
Let me add here: I had a brick wall in our first house we wanted to cut through to install a door. Room had carpet and furniture in it. Fortunate where I was going to install the door already had a smaller hole for a firewood box. I took a 3 or 4 foot shop floor vac and set it in my garage and boxed around the fan. It was far enough away the brick dust fell before reaching the fan but we had almost NO dust in our house.
   / Suggestions on how to clean out DK6010 cab and tractor as a whole? #6
I do as TN8Man does. On my machine the cab vs open station versions are likely equally able to take water in most areas, but not the interior portions of the cab itself.
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2016 JLG 20MVL 19ft Aerial Platform Lift (A55851)
2016 JLG 20MVL...
2012 Audi Q7 Premium Plus AWD SUV (A55853)
2012 Audi Q7...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2012 MACK CH613 DAYCAB (A55745)
2012 MACK CH613...
