Suggestions for a Hydraulic Top Link for a CK30
   / Suggestions for a Hydraulic Top Link for a CK30 #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
I am contemplating a hydraulic top link for my CK30. I do have Pat's Easy attach on it. I am about to get a Box Blade and was thinking a Hydraulic Top Link would be a good idea. From reading I think I want a check valve. Any suggestions as to size, capacity, etc.? I didn't find anything specific while searching and I'd appreciate any help.
Thank you
   / Suggestions for a Hydraulic Top Link for a CK30 #3
I just installed one on my ct225 last week that I purchased from Brian from fit right hydraulics. He frequently posts here as mt. View ranch. I have it in conjunction with a quick hitch & no check valve and I am very pleased with it so far. He has a price list on his website with your tractor listed and was very nice and helpful. They take a while to get because he custom makes it to fit your machine.
It's nice being able to adjust so easily and quickly change implements but I was surprised at how slow the cylinder is, I thought it would be quick and jerky but it's slow and smooth. Get one if you can i think you'll like it, I do.
   / Suggestions for a Hydraulic Top Link for a CK30 #4
I can't offer any help with size, etc. but can say a resounding YES to functionality. I bought a 2006 used in 2009 that already had the top link remote added. I used it with all implements, but especially with the box blade. It is handy.
   / Suggestions for a Hydraulic Top Link for a CK30 #5
2nd on Fit-Rite and Brian. I have both top and tilt, which is the ideal setup for box blade work. Let Brian know you have a quick attach if you have him make up your package of parts.
   / Suggestions for a Hydraulic Top Link for a CK30 #6
Ditto on Fit-Rite and Brian. You cant go wrong with his advice, customer service and pricing. He know his stuff and will not steer you wrong.
And he is also understanding of Dummies like me :eek::D
   / Suggestions for a Hydraulic Top Link for a CK30 #7
I have both Top-n-Tilt, if you are doing any sort of blade work... they make the job MUCH easier. I didn't get mine from Brian/Fit-Rite, although I wish I had.
Thank you all for the suggestions etc. I do have a single remote in the back, how hard and $ is it to double that up? Is there a controlled diverted I could hang off the single that would be relatively inexpensive and give me 2 sets (thinking top-n-tilt)?
   / Suggestions for a Hydraulic Top Link for a CK30 #9
I do not know enough about the hydraulics to help with an answer, but that would be awesome if you could go with top-n-tilt
   / Suggestions for a Hydraulic Top Link for a CK30 #10
Thank you
You can measure the range of your existing top link and use that for guidance. Top link cylinders are easy to find online, and run $150-250 for your size tractor, plus figure another $30-50 for hoses. Do not get a check valve if you want to float the link, which is somewhat common with box blade work or using a bush hog on undulating terrain. I have not seen the need for a check in my use of a top link, but others here need a check due to leak down somewhere in their system.
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A50322)
2025 JMR 36in...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
