Suggestions for 3720 purchase
   / Suggestions for 3720 purchase #1
Michael_Porter
Bronze Member
Southeast Iowa
I'm about to buy a JD 3720 with a cab, 300CX FEL and MX5 rotary cutter. In the JD catalog on the 3000 and 4000 Twenty Series, page 12, there is a inset picture of the FEL with the bucket replaced by a blade. I can't seem to find that blade attachment on the JD website. Any clues?
Also, what other options, features, or attachments would you suggest I consider? I won't be using any mid-mount mowers of any kind. I have no lawn, but I do have 100 acres of woods I like to make trail through, a half-mile of gravel driveway to clear snow from, and 5-10 acres of meadows I mow once or twice a year.
I live in Southeast Iowa.
   / Suggestions for 3720 purchase #2
Mike, there is little information of the blade attachment you are talking about on the JD website.. but what you can do to see a picture of it and msrp cost.... go to the configurator on the site.. select your tractor, then select the attachments... 300cx... configure the loader and the blade will be under accesories on the configurator.... you will see a manual angle blade and a hydraulic angle kit, which requires the extra SCV lines down your loader... I had them put on my 3720 Cab Tractor, just in case I ever get more attachments down the road... If you can I would also spring for extra hydraulic outlets (electric diverter kit)... there will come a time when you will want more couplers.... vertical exhaust was a must for me... I like that feature a lot.. Rear work lights are good too, mine are being installed next week, along with a rear wiper... also don't get cheap and settle for anything less than a heavy duty bucket.... the regular grades are very flimsy.... a few of my friends who have JD Tractors, got cheap and settled for the regular grade buckets.. and lets just say this, they are all bent and warped....and rewelded in areas... and these guys use them for a business..... and they got cheap! And of course they regret it now....
</font><font color="blue" class="small">( Mike, there is little information of the blade attachment you are talking about on the JD website.. but what you can do to see a picture of it and msrp cost.... go to the configurator on the site.. select your tractor, then select the attachments... 300cx... configure the loader and the blade will be under accesories on the configurator.... you will see a manual angle blade and a hydraulic angle kit, which requires the extra SCV lines down your loader... I had them put on my 3720 Cab Tractor, just in case I ever get more attachments down the road... If you can I would also spring for extra hydraulic outlets (electric diverter kit)... there will come a time when you will want more couplers.... vertical exhaust was a must for me... I like that feature a lot.. Rear work lights are good too, mine are being installed next week, along with a rear wiper... also don't get cheap and settle for anything less than a heavy duty bucket.... the regular grades are very flimsy.... a few of my friends who have JD Tractors, got cheap and settled for the regular grade buckets.. and lets just say this, they are all bent and warped....and rewelded in areas... and these guys use them for a business..... and they got cheap! And of course they regret it now.... )</font>
Thanks Jason,
I found it, the Boom-mounted front blade. Available for the 300CX in 72" and 84" sizes. Any advice or experience out there for which size is the better match for the 3720?
Also, there are a lot of bucket choices. Which heavy duty bucket do you recommend?
And again, what about the 4-in-1 bucket? Says it will load, scrape, blade, and clamp material. Will it work as a snow blade?
   / Suggestions for 3720 purchase #4
I own the 3320 and the John Deere 72" blade you are referring too thanks to another TBN member jcmseven!! I am absolutely Loving it so far. Mine has the hydraulic angling and I have loader arm lines enroute (right now I am just using it straight angled. This thing is a tank and it goes on and off in just a few seconds literally. The 72" will work just fine with the 3X20 series - that is what is recommended for the 3X20 and 4X10 series. The 84" is for the 4X20 series loaders.
Other pictures at teh link in my sig file.
   / Suggestions for 3720 purchase #5
Mike, I can't tell for sure from the photos but it looks like there are no skid shoes on the plow. If so, are they an available option? Right now I plow my long gravel driveway with a Fisher plow on my truck and without skid shoes I would be plowing a lot of gravel along with the snow.
Also, it looks like the whole blade is designed to trip as opposed to just a lower trip edge. How does that work out?
   / Suggestions for 3720 purchase #6
Woody,
Mike's blade does have the skid shoes and they are standard, and they are pretty easy to adjust. The spring trip is helpful, but in my limited use of the plow before, they never tripped, mainly because the skid shoes would allow it to ride over an object. I can say everything on that blade is heavy, so it would take a major impact to trip the springs. I really like the boom blades too because one can change the angle at which the blade contacts the ground with the loader angling. So for example if you are plowing and the gravel is being displaced, just angle up and off you go. Very easy to use and according to my dealer, much more refined to attach and detach than the Curtis blade, which they also install.
John M
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
