SUDT2 - Quiet!!
   / SUDT2 - Quiet!! #1
nspec
Platinum Member
Southern Rhode Island
Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
I just did my 300 hour service on my Kubota B2630. A 5 gal. pail of SUDT2 was only another $20, so I figured what the heck, I'll give it a shot. Holy cow! You can't believe how much quieter the tractor is. The hydro whine is all but gone. What you do hear, sounds more refined and less raspy - if that makes any sense. The motion back and forth with the hydro pedal is noticeably smoother.
I know several of you are laughing right now. I'm a big machine guy and was very skeptical of this 'magical new fluid'. I had read a couple of posts mentioning that the super udt quieted the transmissions, and others said it did not. I've got to tell you, whatever it is makes a HUGE difference. Try it, you'll love it.
   / SUDT2 - Quiet!! #2
Wher did you get it for that price??I'd buy 50 gallons if that is the correct price.
   / SUDT2 - Quiet!!
Yes, I obviously meant it was only $20 more than the regular UDT - $107 vs $87.
   / SUDT2 - Quiet!! #5
only one luck you mine took 2.5 buckets
   / SUDT2 - Quiet!! #6
My fault. I was pretty excited............20 dollars more is more like it. I'll pay the price once again when my next change comes up...
   / SUDT2 - Quiet!! #7
Nspec, your findings don't surprise me at all. SUDT 2 is 75% synthetic. If you want to have even better results next time try some 100% synthetic Amsoil tractor hyd/trans fluid. It will make your tractor quieter, smoother and run cooler than ever before.
Before the war starts, I do not work for Amsoil. I only use some of their products and have for about 20 yrs.
When you were changing oil you didn't even realize you would be testing dino oil against synthetic blend. Now that you've seen for yourself how much better a synthetic blend makes things operate this could be a turning point in your life. It only took one eye opening experience for me and I wanted to learn more about what I had been missing. I was open minded enough to go against the grain and find out for myself instead of just following the other sheep down the path like most do. Your eyes have been opened to a whole new world and you are just on the tip of the iceberg. Happy tractoring my friend, welcome to synthetic lubricants and the benefits they have to offer.
   / SUDT2 - Quiet!!
I've been using synthetic for years in engines. This is the first transmission or hydraulic application where I've used it. Also the first time I've actually been able to see/hear/feel an obvious difference as a result.
   / SUDT2 - Quiet!! #9
The first tractor I used Amsoil in amazed me. It started like normal and everything sounded like it always did. About 3 or 4 seconds after cranking it had a noticable drop in engine noise. After that is when I started testing their products in other applications. Over the years I have tried about every synthetic out there. None do what Amsoil does, not even close.
   / SUDT2 - Quiet!! #10
It was expensive,but I replaced the shuttle clutch fluid of my AC 918 backhoe with pure Mobil I synthetic transmission fluid, because I FEARED the job of rebuiding the shuttle clutch and internals. It has worked out really well thru the years,and has not gotten that burned smell or look that other t-r-ans fluid does after a lot of hours. I got a deal thru the Marathon dealer I used to work for so I bought 30 qts. or so at half-price. Haven't had to add much either. don-ohio :)^)
2001 John Deere M665 (A50120)
2001 John Deere...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
