Oil & Fuel Sucking air somewhere?
   / Sucking air somewhere? #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I have a 3525 that will run great until the fuel in the tank gets below the pump return line. Then it starts missing and sputtering as it is sucking air. I am going to change the line(DUH) but before I do, I thought I would throw it out there in case some one has seen this before. I do not smell diesel and there are no leaks so I thought it might be something else. I am not sure how the fuel bypass and return to tank from the injector pump works.
   / Sucking air somewhere? #2
Don’t have the same model, but had a similar issue. I had fabric braided fuel line that had cracked/deteriorated but couldn’t visibly see an issue. Replaced the lines and all is good
   / Sucking air somewhere? #3
Do yourself a favor and buy diesel fuel injector hose in bulk. Anything you replace (gas or diesel), use it. Once and done. Also remember not to use too sharp of bends as they will eventually fail or damage the hose from fatigue. Good luck!
2012 Peterbilt 337 IMT 6025 14,000LB Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2009 MIE Conter Console Police Patrol Boat with T/A Boat Trailer (A50324)
2009 MIE Conter...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
