Interceptor
I have successfully completed the conversion from standard flow to high flow auxiliary hydraulics on a Toolcat. It does require lifting the cab, but after the cab is removed it’s a simple job. The total cost for parts is $1101.39 when purchased at full price from Bobcat’s online store. It also requires dealer programming to activate the high flow option, or someone with access to the dealer software
. A complete parts list will be provided below. Parts and procedures should be the same for all series D, F, and G, Toolcats, and I'm fairly certain UW53/UW56 use the same parts as well. A competent mechanic in a well equipped shop should be able to complete the job in 8-10 hours, most of that time spent removing and reinstalling the cab.
There is no change to the hydraulic pumps, the only changes are in valving, controls, and piping. The sectional control valve does not need to be disassembled. Two plugs get removed from the mid inlet section and replaced with valves. A few fittings, pipes, and hoses get replaced. The wiring for the switch and solenoid are already in place, they just need to be plugged in. While I was at it, I also added power Bob-tach and two additional rear remote hydraulic circuits.
| Quantity | Part Number | Description | Price | Ext. Price | Alternative Part Number |
| 1 | 7024209 | valve | 189.49 | 189.49 | Hydraforce SV10-29 |
| 1 | 7024210 | coil | 108.99 | 108.99 | Hydraforce 6352012 |
| 1 | 6680247 | valve | 82.99 | 82.99 | |
| 2 | 17KB1612 | fitting | 29.49 | 58.98 | 6801-16-12 |
| 1 | 7116046 | tube line | 128.99 | 128.99 | |
| 1 | 7116047 | tube line | 130.99 | 130.99 | |
| 4 | 6679025 | clamp | 5.33 | 21.32 | |
| 1 | 6653493 | plate | 3.67 | 3.67 | |
| 1 | 7115278 | hose | 161.99 | 161.99 | |
| 1 | 7115279 | hose | 168.49 | 168.49 | |
| 1 | 7023087 | switch | 45.49 | 45.49 | not required for UW53/56 |
| Total | 1101.39 |
