Substrate for raised concrete deck
   / Substrate for raised concrete deck #1
Maryberry
I'm having a large concrete deck built which will be about 30" high at the highest point. The question I have is what should it be filled with, compacted soil or rock? There will be concrete walls and a six inch, steel reinforced slab on top and the top surface will be slate tiles. Originally the contracter suggested using drainage rock but now favors soil which is available at no cost. Would the compacted soil be suitable to provide a base for the concrete slab? Appreciate any suggestions.
   / Substrate for raised concrete deck #2
I would go with compacted drain rock.
Sure, dirt is free, but if the dirt is even a little bit expansive it is going to crack your new concrete deck.
You can prevent settling by backfilling in lifts and compacting with a plate compactor between lifts, but you can never beat expansion.
Dave, thanks for the feedback. I thought that rock was better but I wasn't certain. I guess 3/4" drainage rock would be the least expensive and best?
   / Substrate for raised concrete deck #4
Should be close to least expensive.
Around here we can get something called "ballast" which is angular rock screened to be +3/4" -1.5". This works just fine for drain rock and is sometimes less than 3/4" round rock. The angular rock needs more compaction, but the round rock needs some compaction anyway.
2011 INTERNATIONAL DURASTAR 4400 (A53843)
2011 INTERNATIONAL...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
