Subsoiler or Moldboard Plow
   / Subsoiler or Moldboard Plow #1
Bpawb
Which one of these implements would serve best for my project..... I'm trying to prepare a garden(240' x 60') for next spring..... The soil is 4" of topsoil & beneath his very compacted clay...(no oxygen and all)... I'm planning on Tilling
the whole area.... But do you think I should first use a...."Subsoiler or Moldboard Plow".... To disturb the ground below the topsoil? I do not own either implement, and I will be purchasing the one I need....
Thank you
paul
   / Subsoiler or Moldboard Plow #2
Tough call there. A moldboard plow would work the ground to a depth of (maybe) 8 or 9 inches. It would incorperate your 4"s of top soil with the clay. In time, and with the addition of some needed ammendments (manure?) you would develope a deeper "topsoil" structure. But that takes time. And the tiller would finally achieve the same end.
Deep compaction takes deep "ripping" to relieve that problem. A subsoiler would help a great deal there.
My garden ground WAS junk. It was 3 or 4 inches of poor "top soil" with blue clay underneath. I chisel plowed it a few years ago. (to a depth of about 12") I've dumped several tons of composted manure on it every year. Every 3rd year, I turn it over with a moldboard plow to "mix" the soil better. It gets a tiller each spring.
But back to YOUR question about YOUR garden.
I'd take the subsoiler route, then the tiller next spring, giving those choices. A nickels worth of free advice. Subsoilers or deep rippers do a MUCH better job of breaking up "plow pan" or compaction if and when you use them with the soils as dry as you can drag the tool through the ground. They "fracture" soil, rather than just ripping a groove.
   / Subsoiler or Moldboard Plow #3
In some areas the subsoiler is a very commonly used implement. Takes a lot of HP to pull compared to the moldboard plow.
It will help.
Egon
   / Subsoiler or Moldboard Plow #4
If you have a hard layer, ideally it would be the best to use a sub-soiler to help break it up and then a moldboard plow to work the top soil. The only problem with doing this would be having to purchase both implements. BTW, if you get a moldboard don't get a new one. The are made sell but not to use. Get an old Ferguson, MF, JD or Case. They do a much better job and can usually be picked up at an auction or from a local paper very inexpensively.
Thanks for your advice ...."Farmwithjunk".... from what I can tell the Subsoiler would be the implement of choice, but I was unsure..... I might not wait till spring though, to do my tilling,.. around my place(North Georgia) in the spring the ground is pretty wet... I figured break the ground, get it tilled and prepare this fall , then next spring , after it dries some I could re-till if necessary.
paul
Egon , you think 30 horsepower 4WD will do it? It's pretty heavy clay underneath.
paul
   / Subsoiler or Moldboard Plow #7
If you till clay when it is moist you will get a collection of "clay-balls" about 1/2 - 3/4" in diameter. These will then dry up and remain hard, making it very difficult to plant seeds, and the top layer of soil will get very dry, very fast.
Here in Michigan I've had good luck with ripping the soil in the fall, then till the dry clay with leaves/manure/compost. Let it sit all winter. The subsoiler ripping helps the soil drain in the spring, and then I rip & till the last week in May just when I'm ready to plant - the soil has to be pretty dry.
   / Subsoiler or Moldboard Plow #8
Is 30 HP enough? It's a question of how many shanks and how deep. It may be best to ask the implement dealer on HP requirements.
Sorry I can't give a definitive answere.
Egon
   / Subsoiler or Moldboard Plow #9
Folks used to pull single shank subsoilers with 9N,2N, 8N Fords and the like. They're less than 30 HP. The issue is as much weight/traction as it is power. HOWEVER, I THINK you'll have enough of each for a single shank.
   / Subsoiler or Moldboard Plow #10
Subsoiler
Features:
* Heavy Duty 1" Wide x 6" Shank
* 1/2" x 3" Wide x 12" Reversible Point for Longer Life
* Shear Bolt Protection on Top Link
* 15" Middlebuster Shovel will fit on Footpiece
* Grade 5 Heat-treated and Plated Fasteners
* 3 Point Hitch with Replaceable Cat. 1 Lift Arm Pins
* 20 - 35 HP Recommended
* Comes Assembled and Ready to Use
Did a Google search and this is data for a one tine subsoiler that may get almost deep enough.
Egon
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
