Submersible well pump health?
   / Submersible well pump health? #1
tomplum
Elite Member
PNW
XJ2025H
We're not having any apparent issues with the pump. Are there indicators that I can check to determine health of the pump? Like amp draw as an example? Our well is 160' deep and 25 years old. I've no clue if anything had been done with the well itself since. If logic says to replace it, what do I look for to replace it with? I had another thread on the pump house being rebuilt earlier, but it looks like the actual build will be next spring. I thought this may be a good time to ensure the well health.
   / Submersible well pump health? #2
Wow - 25 years on the same pump - that's really good life - get another one like it! As far as pump health you can check the amperage - you need to know the pump HP its probably a 1/2 or 3/4 HP, and an Ampmeter and if it has a two wire (no control box) or three wire (will have a control box) pump motor.
See the attached gould pump manual -the two wire 1/2 HP 230V runs 5-6 amps, and 3/4 HP 6-8 Amps. You can also check the windings with an ohm meter to see the health of the motor.
The biggest thing impacting pump life is # of starts and run time, so either have a large storage tank like Wellextrol, 20 gal drawdown, and or install a cycle stop keeps the pump running during water use.
  • gould pump manual.pdf
   / Submersible well pump health? #3
FWIW: If you are really serious about knowing, well pump specialists can come out and measure the quality of the insulation on the motor, its' efficiency (and therefore wear), but at the end of the day failure is not a predictable event on a single unit. "If it ain't broke, don't fix it."
At that age, I would mentally put aside the money to have the pump replaced, and then don't sweat it. If your water supply is mission critical, plumb in a storage tank with enough of a reserve to get you through whatever you think the delay would be in getting your well pump team out. In clean water, with not running the pump dry, and no lightning induced power surges, pumps can last a long time. You may have a gem!
All the best,
Peter
I have the original install paperwork and 6 years ago they replaced the pressure tank. The rest is a big question mark. We've been here for 5, the last people for 9. My guess is if they had it done that I'd have the paperwork. The only time critical thing here is everything is wide open now. It would just be easier. Thanks for the manual.
   / Submersible well pump health? #5
I looked after and or are aware of most well pump installations on my lake of 75 homes.
They range from lake water to 400 ft wells.
Proper installation is important.
Using all brass or stainless fittings goes a long way to a healthy system as does quality bladder tanks.
(dissimilar metals created corrosion and often quite rapidly)
Most problems that I found were related to air leaks and or corroded fittings with rust growth clogging lines.
From gathered experience my observation is that 25 years is definitely to be expected and probably much more.
I know of some installations that are in the 50-60 year range.
Many modern improvements (fiberglass bladder tanks, solid state relays etc) will assure even longer life.
One common maintenance item is the start capacitor so the pumps that have the control box in the pump house are at an advantage.
Pressure control switches are probably the most common item but fortunately always easy to reach and at a reasonable cost.
   / Submersible well pump health? #6
My five horsepower pump is at 440 feet. This summer a wire came loose and shorted to ground. The pump had to come up to effect a repair. I replaced the pump and motor as well as the controller. I felt after twenty five years it was a good time. My neighbor's pump went in at the same time as mine. He started shedding blades from his impeller within a month of me replacing my pump. Yes, we both have Cycle Stops. In my experience I've not needed to replace a start capacitor. I have replaced the run capacitor a couple of times.
   / Submersible well pump health? #7
I've got 37 years on a sta-rite 20gpm pump, hit by lightening twice, pulled like 5 times to replace drop pipe rust through, 3 or 4 pressure switches, rebuilt control box.
   / Submersible well pump health? #8
I'll add that using blue poly B pipe has paid off big time. No rust thru to contend with.
Also learned early in the game to use dual clamps on all fittings as they do rust away.*
And I always heat the fittings B4 clamping the Poly B as it really makes the barbed fittings hold well.
Oddly enough stainless barbed fittings are currently cheaper than brass so it is the way to go now.
*While the hose clamps are stainless I discovered the clamping screws are plain hard steel so they tend to corrode, hence dual clamps to better the odds.
I've not pulled the cap to do a visual. Nor any electrical test yet. The thought popped in my head about how long they should last and the Googler said 15 years. It got me thinking. For most of it's life, it dealt with a family of 3 for ~ 10 years and a couple owned the home before us. It's just us two now for the most part.
I had to move my pressure tank when the pump house came down. Lots of rust in the galvanized pipes from the adapter to the tank. All outside will be PVC. Good to hear that pumps can last a long time. My only other experience with a well was a non submersible pump.
My well output is apparently on the low side. Not that we've ever noticed. I can fill a bucket faster than I want to fill it. I don't really know what affects that. We had a well test / water test done 5 years ago before buying. It's lowest is 5 gallons per minute on an extended test. That is the same as what it was when it was put in back in the 90's. Though since we bought, I had replaced the supply line with 1" PVC to the house and 3/4" to the shop. It had that lovely blue pipe that failed. I don't recall what that was called. We had one of those break on my other house about 3 months after their special policy ended.
   / Submersible well pump health? #10
Why use galvanized steel pipe?
Poly pipe will NEVER "rust through"
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
