Backhoe Subframe mounted back hoe seat mount???
   / Subframe mounted back hoe seat mount??? #1
countrybumpkin
Elite Member
Kioti, kubota
I have a Kubota with a sub-frame mounted backhoe, it uses a seat that mounts to the back hoe which worked fine but now I have added a Canopy and can't use the seat with the canopy due to head clearance. The canopy is mounted to the top of the rops and would need to be about a foot higher for head room to use the seat on the backhoe, so I was wondering if anyone else has had a similar problem or use a different seat method for a sub-mounted back hoe, maybe modified the tractor seat to work sort of like a full size back hoe seat does or something. Any pics of your seat seat ups would be great thanks.
   / Subframe mounted back hoe seat mount??? #2
I don't have a BH but I once used a friends tractor that had one. He had the same problem but with head room using his stock canopy mounts. He made new brackets (L shaped steel plates) that U-bolted around his ROPS that raised the canopy about 10-12" higher. You may have to make some too.
Thought about mounting it higher but the canopy is tall enough as it is hate to raise it another foot. That being said I have thought about making some sort of extendable mount that I could raise the canopy while using the BH and lower it when the BH is not needed.
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
2021 SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
2021 SELLICK...
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
