sub soilers for rock removal
   / sub soilers for rock removal #1
john1946
HELP...!!!! Read all posted on sub soilers and tooth bars, etc... Would one of you guys please help me determine what I need for rock removal. If I get a tooth bar it will take up more ground that I want. I also want to use THIS implement for getting under surface roots to get them loose. What is the best implement that you would recommend for performing both of these tasks. Oh, I forgot to mention that it will be attached to my NEW JD2210.....
THANX /forums/images/graemlins/crazy.gif
   / sub soilers for rock removal #2
A sub soiler will NOT pull rocks to the surface, if it hits one it will more than likely push it sideways. A subsoiler only cuts a path a couple inches wide (the blade itself is only about 1" wide on the bottom of a shaft that is about 0.5" wide) so there is really nothing to grab the rock and pull it up to the surface. A sub soiler will cut roots provide you are not trying to cut the root of a large tree.
A box blade with the scarifier teeth down will do a better job of bringing rocks up.
However your concern about the toothbar (I presume on the FEL) tearing up too much ground has me concerned because a box blade will tear up the ground very effectively too.
Hummm....guess it's back to the drawing board....
Again thanx. You obviously have done your homework....
2005 TerraGator 8104 (A52748)
2005 TerraGator...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
