bunyip
Elite Member
Not really for the Kubota forum as it is a general thought on peoples perceptions of sub compacts.
I have a BX2370 and was out leveling sand in the arena a few days ago when our stock agent came in with some 20' x 7" poles, he had trouble getting a gate off the tray as the poles had moved and were pushed up hard against it so I raised the bucket and gave them a push so he could remove it, that done he dropped the poles in the arena and asked if I wanted a hand to move them, I said it was OK and I would pick them up with the jaws on the 4 in 1 bucket and drop them over the fence.
He became alarmed and said that I should be very careful as I would probably tip the tractor over, yes the poles are heavy but not anything that the tractor couldn't handle and after he left I grabbed them one at a time and raised them about a foot off the ground, drove to the fence raised the bucket about 5' shifted forward and dropped the poles, repeat another 5 times, too easy.
Despite the compact nature of the tractor it weighs just over one ton and has a low centre of gravity, the grader on the rear whilst marginall lighter than the counterweight sat out about 4' so easily offset what I was lifting.
The poles were picked up in the centre so were balanced and there was no struggling with the lift.
I suspect people look at the size and think it is just a ride on mower with a bucket whereas it is quite a serious and capable tractor that can do everything I want around the place, we started looking at 40hp tractors and decided that it simply wasn't necessary when this would do everything we want and more.
Have others encountered the same perception with sub compacts?
