etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,084
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
The subject is my question. How would a 14 HP air cooled gasoline engine compare to an approx. 27 HP liquid cooled diesel engine. I know that on an equal type basis the gas engine is going to use about 20% more fuel than the diesel when powering the same load. But this is not an equal comparison. The gas engine is an overhead valve air cooled generic engine in a Generac generator. I said generic because I'm thinking that all the engines made for this type of work are pretty much the same. Especially since, for the same wattage generator, the engine brands chosen for the generators tend to change over time. The diesel engine is in a Yanmar YM2310. The PTO output is rated at 23 HP. The engine HP is about 27 HP. I say about because I have seen the output rated from 23 to 28 HP. If the PTO is rated at 23 HP the engine must be rated higher. So I'll settle on 27 HP.
But the engines will only be under a partial load, say 8 HP. So with a light load will the diesel use less fuel than the gas engine? Anybody have more than a gut feeling? Will the diesel use less fuel?
The tractor in question is the first diesel engined anything I have ever owned and I am learning a lot about them. I already have an appreciation for the fuel usage. For the time run and the work accomplished it is way better on fuel usage than my 80 year old Ford 9N gasoline powered tractor. But that's not really a fair comparison considering the side valve engine in the Ford compared to the overhead valves in the Yanmar. But the John Deere riding mower that my wife loves do much to use has a 23 HP overhead valve engine in it and it uses way more fuel per hour than my Yanmar.
Thanks,
Eric
Thanks,
Eric
