STX38 intermitent pto clutch
   / STX38 intermitent pto clutch #1
dscrut
Montpelier, VT
JD d100 and STX38
I have a black deck STX38. I replaced the PTO clutch and cleaned the battery and ground connections but still the tractor will mow for a few minutes and then the clutch disengages. It will occasionally come back on for a while but will not keep running.
Any ideas?
Does anyone have a full wiring schematic?
Any ideas?
I had put a new battery in before the problem started and did not charge it before I used it. I tried charging the battery and mowed the whole lawn without a problem. With the battery charged I have13.2 V not running and 13.6 V with engine running. This seems right to me I wished I had checked before charging the battery. Does anyone know what the voltage should be across the battery when running?
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
