STX steering wheel
   / STX steering wheel #1
Tom Thomson
John Deere STX 38
The steering wheel on my STX needs to come off but it really really doesn't want to. The cross bolt thru the wheel hub and shaft is well and truly stuck. After using a hammer driver and then an air impact gun the phillips drive in the screw head is kind of wallered out. Not enuf room to get on the head with vise grips. Any thoughts?
tommyt
Well you guys, I got it out. If anyone else wants to remove his steering wheel, don't even try to unscrew what appears to be a phillips head bolt. THERE IS A TRICK!!! The thing that suprises me is that none of you JD experts knew about it or worse knew and decided not to say anything. Am I wasting my time on this forum?
tommyt
   / STX steering wheel #3
Ummm, I'm no expert, so are you just going to keep me hanging ???? :p
What's the big 'trick' to get it off.
I'm glad you figured it out !!! :thumbsup:
Ray
The trick is that the "bolt" is not threaded, it is splined and driven in. The biggest screwdriver in the toolbox won't turn this puppy. I guess the phillips cross recess is just to sucker the new guy. Take off the nut on the other side, use a soft drift and a small hammer (don't bugger the threads) and tap it out. I am dissapointed that no one responded to my initial inquiry.
tommyt
   / STX steering wheel #5
Ray
tommyt
Thanks Tom. What was your reason for removing the steering wheel in the first place ?
to replace a leaking gas line
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
CUSHMAN SHUTTLE GOLF CART (A51406)
CUSHMAN SHUTTLE...
