Angus99
The dealer is prepping my new 3130DT and I've asked him to install some hooks on the 723 loader bucket to allow me to use a chain to pull up stumps. We're selectively clearing saplings & scrub out of a heavily wooded front yard--we want to keep the large trees and healthy immature trees. I live in the South, where stumps never seem to die unless you poison the stew out of them--which I'd like to avoid.
The stumps I'm pulling are fairly small --3-6 inches dia max near ground level. I've done this with a chain wrapped around the drawbar of my old Ford 640 and they pop right out with a running start--often tearing up the ground with the ag tires. Now that I have 4WD and a loader on the way, I'd like to minimize soil disturbance by just lifting them out, if possible. Also, using a chain allows me to reach stumps between the trees I want to keep; just using the bucket to bust them out won't be an option since the keepers are so close together. I do not have filled tires, but have a 400-lb back blade to counterbalance some of the lift force.
Any cautions about the equipment or technique? Any better ways to do it? Finally, where should I have the hooks welded to minimize damage to the bucket?
Thanks!
Ian
Thanks!
Ian
