foggy1111
Elite Member
How many hours will I spend to grind about 200 stumps to about 4 to 6 inches below the ground??
As soon as the ground thaws out here (April I hope) I plan to rent a VERMEER STUMP GRINDER from the local rental yard. The model they have is self propelled and sweeps hydraulically ...but I am unsure of the model number (SC252 ??).
The trees are all red pine and have been sheared off by the timer company before I bought the property...about three years ago. Most are about 4" above the ground and vary in diameter from about 8" to 14". The ones I want to grind are mostly along my trails....so they are fairly easy to access and mostly lined up...from one to another (plantation).
I am also concerned with issues about the teeth. Do teeth break or become dull if operated in too much soil? (my ground is all sandy loam) Is replacement a big factor? I am told the carbide teeth are pretty spendy.
I have never run a stump grinder.....so.....Is it reasonable to plan for about 100 per day? ....for a two day ordeal? ....If I work real hard and have a little help?
Thanks for any experienced replies.
