BobRip
Elite Member
I was cutting a few small stumps today and the stump grinder disc came off the motor. I figured I had lost a bolt and worst case I needed a new bolt and a key for the keyway. I went home and took a closer look and there was a break on the blade outside of the hub weld. Initially it looked like the weld was broken, but it was acutally the disc. The blade and hub are still intact, but loose. I have attached pictures and would appreciate any suggestion on how to weld it back. Please note, I have a gas welder.
Should I grind into the crack or just fill out the weld from the hub to outside of the crack.
Or maybe you have a better way.
