stump grinder trouble
   / stump grinder trouble #1
maurer
pickering ont
bobcat skid steer
I have a sg60 stumpgrinder that the solinoids do not work on the unit.Got power and ground on the power cable going into the curcuit board on the grinder.
Anyone had this problem?
   / stump grinder trouble #2
What model & year machine do you have it on? Has it worked on this machine before or is this the 1st time hooking it up?
Modle # is SG 60, YEAR IS 2008 ? The unit will not work on my other bobcat as well. Thanks for any help you may give.
Wayne / in pickering -ont. canada
   / stump grinder trouble #4
With everthing turned on and working correctly there should be (2) 12 volt supplies to the module. The red w/white stripe wire to pin #2 in in the connection plug on machine is unswitched power. The orange wire to pin #1 is switched power, to test - turn key on (do ont start), push Auxiliary button in left panel twice (max flow light comes on) and click the front trigger on Right hand steer lever once. If there is no power to the orange wire at the connection plug you need to trouble shoot the loader. If you have power at both wires to control module and ground is good back through the black wire and nothing works with machine running, I would gues it is a bad module. The 4 purple wires are computer communication wires only.
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
DOOSAN DL300-3 HYD 4N1 114" BUCKET (A51247)
DOOSAN DL300-3 HYD...
2014 KENWORTH T680 SINGLE SLEEPER ROAD TRACTOR (A51247)
2014 KENWORTH T680...
LMC G500-500A LOT IDENTIFIER 93 (A53084)
LMC G500-500A LOT...
