stuck valves
   / stuck valves #1
royzane
southern CA
1991 ford/new holand 555c
I have a ford/ new holland 555c backhoe with ford controls on it. the swing and crowd controls dont seem to disengage all the way when i let go of the controls. I have to manually return the valves to neutral. It may be a linkage problem or it may be in the valve block. the linkage seems pretty tight but its hard to tell, the controls dont seem to stick until the machine has warmed up quite a bit... any suggestions? new o-rings ? rebuild valve block? linkage? any help would be greatly appreciated! oh yeah, my dad is looking for an enclosed cab for his 1989 ford 555b model backhoe, please let me know if there is one out there!
   / stuck valves #2
The first thing I would try is to remove the detent caps from the bottom of the valve and see if the detent spring is broken or rusted up. Let me know what you find.
Partspring has the original New Holland parts for that 555C.
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
1265 (A50490)
1265 (A50490)
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
