Stuck shear bolt remnants
   / Stuck shear bolt remnants #1
Ken P
North Granby, CT
Kubota B2410
Folks -
I seem to have snapped off one of the shear bolts holding the augur to the shaft of my kubota snowblower (B2782 if it matters). I guess I must have been continuing to work for awhile, 'cause the snow was pretty packed in on that side when I stopped.
Anyhow, I can't seem to get the remaining piece of the shear pin out. I can wiggle it around a bit, and rotate it a bit with a little metal pick, but it doesn't seem to want to come out. I tried to whack it with a nail set and a mallet without success.
Anyone with suggestions? I tried to do a search, but either this isn't a common problem or my search techniq
Sorry, managed to fumble-fingered click on submit reply before I was done. Moderator please remove this thread, the other one is the complete post.
Ken
   / Stuck shear bolt remnants #3
To Ken P
I believe you are still asking a question. When a shear bolt gets to drive for some time on only half of its self it gets ( S ) shaped in the hole. Sometimes the outer drive sleeve gets burred. You need to drill out what you can without damaging the shaft or sleeve. use a sharp good quality drill and try to pick up the center of the pin. If you run the drill in reverse at the beginning that helps to center the drill. I learned this trick from machinists. Don,t break the drill off in the shaft. The other method is to use a quality straight pin punch and hope that you will be able to ( BASH ) it through, I have found this to be 50/50.
Craig Clayton
Craig, thanks, see my results (worked) on the other thread.
Ken
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
40' CONTAINER (A51244)
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
