Stuck PTO shaft on Finishing Mower
   / Stuck PTO shaft on Finishing Mower #1
SgtSluggo
Bronze Member
Middle TN
John Deere 4105, Ford 1700
So I am trying to get a Farm King y750r finishing mower working again. My current problem is that the PTO shaft is kinda stuck. The release on either end seems to be stuck and the two halves of the PTO shaft are stuck together.
Does anyone have any advice on freeing everything up and what I should check after getting it apart/greased up again?
   / Stuck PTO shaft on Finishing Mower #2
Penetrating oil, a big hammer, a block of wood and time. Hose it down and start carefully hitting it to get it to move. Wood goes between the hammer and what your hitting.
   / Stuck PTO shaft on Finishing Mower #3
If lucky, sometimes light tapping sets up a vibration that breaks the rust bonding.
You'd try that B4 using penetrating oils.
We once did that tying one end to a tree and pulling while tapping and it worked.
Then comes cleaning the shafts! Male shaft is easy, but the female? good luck! (and patience)
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
