Stuck parking brake on a TN 75A
   / Stuck parking brake on a TN 75A #1
Steamboat55
Denver, Colorado
TN 75 A
Help!!
When I pull up the handle on the parking brake (TN75A), it sets but won't release. When I push in the little orange knob at the end of the parking brake handle to release the brake, it fully depresses, but it does not release the brake- Its almost like the connecting rod is now too short to release the "ratchet". Sprayed a lot of wd40 on it, seemed to work for a bit, now its acting up again.... When I knock it around a bit, it will sometimes release....
Any ideas??
THANKS !!!!
   / Stuck parking brake on a TN 75A #2
Are you also pulling up on the handle before using the button to release? If so, you may need to just lube the cable thoroughly and/or also adjust.
Roller (A52377)
Roller (A52377)
Wacker Neuson G25 20kW Towable Diesel Generator (A51691)
Wacker Neuson G25...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2022 UTILITY FS2CHA 48FT FLATBED TRAILER (A53426)
2022 UTILITY...
