Traction stuck in the mud
   / stuck in the mud #1
Johno Geo
Chicago. IL.
NH-4060, Ford 1520, JD 345
In NW Indiana , My JD 345 gets stuck when mowing on rural property.
I have a Utility Tractor, rescue vehicle, but it amazes me how little it takes to stick the so called garden tractor, which is really a lawn mower.
I felt like the Village Idiot, as the wheels would coat with mud and the deck would dig in and end of traction..........
I saw my neighbor , for the first time since last fall. I told him I was stuck.
He was a bit sheepish and told me his brand new 0 turn mower was stuck as well.
Come to find out, all my neighbors with 0 turn and garden tractors were stuck!!
I have come to the conclusion any water... you are stuck!
Any Ideas??
   / stuck in the mud #3
I wounder if any one has put water in the drive tires on any of these? I fig that if my big behind balast is in the seat it should not get stuck but my tires spin alot also.:)
   / stuck in the mud #6
You could get bar tires for it, but there is a limit that beyond it, you will get stuck.
The "wait till it dries" enough to not get stuck is highly recommended. Tall grass is better than mowed lawn with ruts in the mud, IMO. ;)
Just "being wet" won't get you stuck. Being swampy and squishy mud will more likely do it. :)
One like this in the thread
http://www.tractorbynet.com/forums/showthread.php?p=2372495#post2372495
should put you a step above your neighbors and less likely to get stuck. :)
   / stuck in the mud #7
The X748 has arrived - TractorByNet.com
I agree with beenthere, much easier to wait until it dries out some, the ruts you make are alot more trouble to fix in a lawn.
Most lawns like Fescue can benefit by allowing to grow tall ever so often as it allows the roots to get bigger and deeper. A couple of mowings when it dries out and you should be in good shape.
   / stuck in the mud #8
Obviously you need a Harbour Freight 12V winch. :D:thumbsup::D
   / stuck in the mud #9
Put chains on. I run chains all year with 2 wheel drive 420, 455, 495 and 749. Mowing, blading, snowblowing or whatever else. If it's a little wet it doesn't matter. I doesn't hurt the lawn at all unless you start spinning the tires, but it takes a lot to spin then. If that happens, in a couple weeks it grows over. It doesn't ride as smooth down the road, but I ran them for 25 years already without a problem. I would not need to most of the time but when it's wet they dig in and don't leave a mess like I thought the would so I just leave them on. But my lawn isn't a manicured lawn like you see in the magazines, but it's a fairly decent lawn.
   / stuck in the mud #10
As my neighbor does..lift deck to next higher setting,full throttle go like heck.
I use weed whacker until ground firmer.
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
