Apr 3, 2011 / Stuck in Gear #1 B buckly2 New member Joined Apr 3, 2011 Messages 1 Tractor 1973 JD Barkhoe I Have a 1973 410 Backhoe that stuck in gear, High and Low range works fine just unable to change gears,any ideas would be helpful. Had this machine for about 20 years.
Apr 3, 2011 / Stuck in Gear #2 Zebrafive Super Member Joined Aug 5, 2010 Messages 5,635 Location South West MI Tractor John Deere 2030, John Deere 6415 Pull the cover that has the range/reverse and gear shift sticks. Check the shift rail that the gear shift stick engages, it may be broken.
Apr 4, 2011 / Stuck in Gear #3 Tx Jim New Member Joined Jan 26, 2007 Messages 10,276 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Zebrafive said: Pull the cover that has the range/reverse and gear shift sticks. Check the shift rail that the gear shift stick engages, it may be broken. Click to expand... Zebrafive is correct as the shift rails have a history of the steel tab cracking and breaking off.
