Stuck hydraulics
   / Stuck hydraulics #1
OC4me
LS Tractor XG 3032
Has anyone had this issue? The Joystick for the hydraulics is stuck. I am interested to know whether this is a dealer service center only fix or perhaps a possible DIY solution. Thanks!
   / Stuck hydraulics #2
Have you tried checking for dirt or rust that is obstructing the movement?
-Doodle Jump-
   / Stuck hydraulics #3
Quite often it will be dirt/rust under the detent caps of the valve.
   / Stuck hydraulics #4
I've had valves freeze up from years of accumulated condensation froze under a cap that the spool moved back and forth in.
   / Stuck hydraulics
I took the boot off and inspected. No rust or dirt accumulation, looked clean. The tractor wasn't on when I did that so I will try again to operate with the boot off while running to see if the valves are movable or frozen somehow.
Thanks!
   / Stuck hydraulics
Turned out that the cable bottom end was froze up. Unscrewed from the hydraulic control unit below, sprayed in WD40 and was able to loosen the cable up.
Thanks for everybody's comments.
   / Stuck hydraulics #7
Lose the WD 40 and apply some spray lithium grease instead. WD is worthless for lubrication anything. It's a water dispersant (WD)... Motorcycle chain lube in a spray can is what you want.
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
1042 (A50459)
1042 (A50459)
